WLAN issue
4 replies · 2,072 views · Started 10 May 2007
i currently have a netgear set up in my house. i have an ethernet box from telewest down stairs and a netgear receiver upsatiars.just wondering if it is possible to use that to connect to the web with my n95,when i search for avaliable WLANs it says none found?any help is much appreciated, thanks steve
snuge wrote:i currently have a netgear set up in my house. i have an ethernet box from telewest down stairs and a netgear receiver upsatiars.just wondering if it is possible to use that to connect to the web with my n95,when i search for avaliable WLANs it says none found?any help is much appreciated, thanks steve
the Netgear box? It may not be "casting" it ..
then on the N95 use Tools / settings / connection / access points / options / New Access Point
Name it ..
Data bearer = Wireless LAN
WLAN network name .. enter the SSID manually
Network status = hidden
The rest I leave to you .. but yes its possible .. 😊
when i try to desplay my wep code on pc it comes up as ******************
any idea how to revela or find it out?
