i got a program to recover it as its hidden data but something tells me that its not right for example 457D9F2F-65A1-4B46-BAE9-A9B8*********.should it be that long etc??
how to find wep key????
i'm guessing the program you've used is wzcook...
anyhoo - yes that is correct. The values are stored in HEX not ASCII
If i remember rightly, you don't need to copy / paste the whole line as there are some lines which are padded out with 00000000000000... at the end
just copy the stuff before this and you should be ok
