Hi guys,
This is my first post on this forum, although I have learnt a lot from this forum, thanks to u guys, u all are awesome.
Regarding what I would like to know is, I have been using MP3 RM converter 1.0 as well as 1.3 version to convert my mp3 files to rm files, as they take very less space. Eg: I have converted a 19 MB audio files to 3.5 MB size using the above. But the problem with this converter is, it doesn't convert it into an audio only format, instead converts into audio & video format. When I play them on my N70 mobile, it gives message, unable to play file, playing partially audio or video and audio starts, sound clarity is great.
I have tried many other converters like eazy real converter, real producer plus etc etc but they don't compress as much as MP3 RM converter does, but the only catch is it converts into rm format with audio & video format.
So please suggest me a converter which converts MP3 files into rm or ram files with highest compression (like MP3 RM converter) and also gives audio only format of rm.
Thanks in advance to all of u.
Regards
AKK
