hello, sincee i had to reinstall all the original ack, my sms doesnt work anymore. everytime i try to send a short message, it tells me "not found" before opening the screen where i could write it. i reinstalled and reinstalled...but nothing changed... does anybody know why and what to do ?
by the way; how can i format it with a key combination at startup ?
I'm glad i found this site
best regards
philip
try use chr+ctrl+Shift+F after you restrart and press this combination of keys when The Saking Hands immage appears
thanks but it still dont work
it has to tell me something if the combination keys works right ? because when i do that, i tried 5 times, nothing happens.
Somebody told me too tu use shift +tab+F..but it is the same.
Do you have an idea for the sms problem ?
Philip
shift+ctrl+f togrther when u see the white screen after re-boot.
It'll work,I just did it!!! 😉
i just did register 8)
i am werewolf now
philip
hello i am werewolf
thanks for your help
" quote" Welcome aboard :P "end of quote"
