Make your Mp3s louder
0 replies · 4,729 views · Started 11 May 2007
here is an app to make mp3s louder on the n95 (some ppl say it isnt loud enuf), its a small pc app (2.2mb) called mp3Gain, it lets u select what gain u want to use for all your mp3 files, just instal it and run it, then click on add files and choose ur mp3s, then whare it says Target "normal" volume set it to 102 db, default is 89 db, if u think 102 db is too high just put in less, once uv done that select track analysis and it will check the gain of all ur mp3s u sellected, then select file, select all files and then select modify gain at the top, then apply track gain, once fineshed close the app down, and enjoy louder music on your n95, its best if u use ur own headfones as the supplied ones are crap and restrict the music abilities.
DOWNLOAD MP3Gain pc app here http://www.savefile.com/files/713773
heres a sample iv modified with MP3Gain, its 4 mb and the track is Roxette - June Afternoon, try it out http://www.savefile.com/files/713795
