Lights On (v. 1.03) ?
0 replies · 1,695 views · Started 12 May 2007
Hello,
I installed Lights On (v. 1.03) in my N95 (Memory card)... but any chance... my display always switch off...
Of course I connected a charger... I don't think will work this Lights On without a charger ?
Do you know why ? :con?
Anybody here ?
Thanks for your help!
PS: Lights On is a software service which is able to automatically turn on and keep activated the screen light of the phone as long as the charger is plugged in or based on a timeout period. The screen light will never turn off until either the charger is plugged out or the timeout expires. It will also try to keep the keypad unlocked if you set this. You can also manually turn the light on/off using the applications settings.
