connect mp3 player of n95 to stereo system using microphone jack
4 replies · 3,862 views · Started 12 May 2007
can you do this, use the microphone jack of the n95 and plug into the line in connection of a stereo system?
or would I wreck my 95?
bras4real wrote:can you do this, use the microphone jack of the n95 and plug into the line in connection of a stereo system?
u meen use the headphone jack (3.5mm) and plug it into a hi-fi (RCA input), yes this is safe to do, u can use the cable u get with n95 (the vid/audio cable) but id recomend buying a 3.5 mm jack - twin RCA audio only cable coz the 1 in the box does video out also, then wen u plug it into the n95 select MUSIC STAND
you can also use the same cable to connect to a car stereo if you have the right inputs. works brilliant for gps also
Hi all 😊
I want to connect my N95 to my car radio but don't know how?
I have a New vauxall corsa with CD30 MP3 and it has a aux, but i don't know how to change this to a 3.5mm jack socket, can someone please help?
bluedav
bluedav wrote:Hi all 😊
bluedav
What do you mean, change the AUX to a 3.5mm jack?
You dont need to change the AUX to anything, it's either already a 3.5mm jack or RCA.
So depending on what type of AUX you have, you either need;
http://cgi.ebay.co.uk/3-5mm-Stereo-Jack-Lead-Cable-1-2m-3-5mm-Jack-to-Jack_W0QQitemZ120121743573QQihZ002QQcategoryZ31492QQrdZ1QQcmdZViewItem
OR
http://cgi.ebay.co.uk/3-5mm-Jack-to-2-x-RCA-Phono-Stereo-Audio-Cable-1m-Lead_W0QQitemZ270121788875QQihZ017QQcategoryZ96943QQrdZ1QQcmdZViewItem
