Hi
I just got a N93i and the TV out was working fine, but now it says enhancement not supported everytime I connect the cable. It all happend when I installed Python for series 60
Any ideas?
Hi
Any ideas?
Try remove the last installed application. If that not work, well, try a phone reset. Check also if you have the last firmware inside.
how about a Nokia Software Updater? look for a new firmware might help..
I have a n95 so I am not sure if it is the same or not, but under your enhancement setting there should be something for the default connection, try to put TV-out as default. Again I am on n95 I have the same port for headphones and video out, so I am not sure if it the same for you but u can give it a try
format phone. it always helps
I just started having this issue on my N95, everytime I plug in the headset, "enhancement not supported" comes up everytime.
Very annoying.
