N93i SIP and VoIP
6 replies · 25,722 views · Started 13 May 2007
talked with 3 different nokia representatives.
1 from USA 2 from Malaysia.
One of them says that N93i is supporting SIP and VoIP. She says I cannot make outgoing calls because of wrong settings.
Please correct me. I'm registered with the SIP server. I entered SIP address in contact book "SIP" subject. Is it not supporting VoIP or what?
It support VOIP, but the SIP on phones is hard to configure. For me the best way, is do the configuration by Fring. So install the free Fring, and star use all VOIP things.
nj7 wrote:It support VOIP, but the SIP on phones is hard to configure. For me the best way, is do the configuration by Fring. So install the free Fring, and star use all VOIP things.
ok... does anyone know how to configure it? or did anyone succeed before?
but why the representative says it is not supported (VoIP)? hmm..
Fring.. i'm looking forward it.. thanks..
soongteck wrote:talked with 3 different nokia representatives.
One of them says that N93i is supporting SIP Phone and VoIP. She says I cannot make outgoing calls because of wrong settings.
I'm pretty sure it supports VoiP. You might have to fiddle around with your settings, but it should work. Let us know what happens.
Thanks for suggesting Fring! I have a similar issue with my VOIP phone. I'll check out Fring.
