Deleting Applications After Flash?
3 replies · 2,086 views · Started 13 May 2007
I have just flash my Orange N95 to the latest firmware however in the application folder there is no Internet Calling Icon (maybe as I restored my settings from pc) and there are still icons of my old games which when I try to delete I get the 'Delete failed' message.
Any ideas how to get up and running again?
Also when I try to restore my messages, It laggs my pc and then fails.
I have another backup on my memory card but when I try to restore, it says I do not have enough memory. Any ideas what to do pls?
mobad wrote:I have just flash my Orange N95 to the latest firmware however in the application folder there is no Internet Calling Icon (maybe as I restored my settings from pc) and there are still icons of my old games which when I try to delete I get the 'Delete failed' message.
Unfortunately, it's not always advisable to restore after flashing to higher FW release or after de-branding the FW
Both PC Suite (on your PC) and the Memory Card Tool (in the N95) utilities can mess up / delete things required by the new firmware when you do a restore.
It is safe to Synchronise using PC Suite after the format, but don't try to restore a backup.
You should be able to resolve your issues by formatting the internal memory on the N95, with *#7370# but be aware that formatting the phone memory will clear all contacts, calendar entries, etc.
Or you could just reinstall the applications manually (sending over the sis or jar files again) as this re-enables uninstallation as well. If you backed up to your memory card put it in mass storage and look for the backup folder - delete everything in there and the nags go away too.
Or you could note the apps or games file name in the app manager then using a card reader locate the files in the 'private' folder on the card and manually delete them.
