Removal of front cover
5 replies · 2,933 views · Started 08 January 2003
Ok i did a search and wasnt very conclusive... is it possible to remove the front cover so I could spray it black [i cant find ANYWHERE selling black covers 😞 ] If so... how u do it? What tools would i need?
this should sort u out 😊
http://www.dr-nokia1.pwp.blueyonder.co.uk/dismantle/7650_disassy/start.html
Hey Zipper.....
As I don't know where in the world your job has taken you today :-? , heres a link in the UK that sells the opening tool and the data cable , or both for the 7650.
http://www.cellsavers.co.uk/acatalog/Cellular_Accessories_Nokia_7650___7210_6610__3610_68.html
Use Google and type in "7650 opening tool" there may be something closer
Cheers....
Sorry Forum Elders, and the likes of for the multiple posts, but every time I tried this morning it said failed and went to a debug screen.....
Didn't mean to do it really
:angel:
Yeah the opening tool is good, especially if you dont want to try the cheapos approach :P
If you feel like taking your life (or your phone :P ) in your hands then you can use 2 long but thin needle type screwdrivers and sliding them gently along the metal track but this is not advised so get the tool hehe 😃
