After turning my 6680 on and then off and then trying to turn it on again- phone is dead. After an hour or so I tried to turn it on again and it turns on fine. I tried the same process again and ended up with the same issue- I have to wait one hour untill I can turn it on again. The battary is full.... would a hard reset solve this problem? Thanks.
6680 have to wait one hour to be turned on again
motman wrote:Hi,
I have same problem with u mate.. My solution is reinstall ur firmware using nokia software updater..
nouxxer wrote:I have same problem with u mate.. My solution is reinstall ur firmware using nokia software updater..
Thanks for the tip mate. Is this solution solved the problem on your phone?
I had a simular problem with my 6680, but my just restart when I ended a call... But that was fixed with a firmware reinstall.
