is possible to change the nokia 5500's cover?
4 replies · 16,185 views · Started 13 May 2007
hi,i'm italian guy,i would to know if it possible chenge the cover on my smartphones,because i'm loking for in evrey site,but i don't find anything..i ask also in other italian forum,but they don't aswer me!please help,i'm in you hands!!!:frown: :frown:
thank's so much
j4ck
p.s.
sorry for my horrid english:icon13: :icon13: ..
it is possible but i found only one site (few months ago so i dont remember anymore 😛) and it was belgian
That Youtube video has disappeared, anyone happen to have saved it/ know where else it can be found? Can't find instructions on how to change the cover anywhere.
Thanks.
If you mean just the keypad yes. It just peels off the double sided tape. The new keypads sometimes come with a new double sided tape so... The tape is very very good and I reused mine without a problem. The new keypad is 10 times better than the OE one. I ordered 3 just in case they failed quickly.
If you mean the metal piece then... It comes off after you take the screws out from inside and then you can use a guitar pic that has been thinned down to release the clips between the metal and plastic. The metal will typically not survive without bends in it.
