divix player question?
4 replies · 2,354 views · Started 13 May 2007
it the divix player for the n95 any better than the real player installed?
what does it play/do better than the real player?
is it worth putting on and where can i get it from?
1. it is much better because it will play avi's instead of stupid "real" format movies and clips
2.see above
3. search for divx mobile, you have to register and then you will be able to download it. It is free.
