E65 sync Outlook contacts subfolder?
3 replies · 3,276 views · Started 14 May 2007
Hi!
Does the E65 able to sync with Outlook in regards to subfolders in Contacts? Cuz I have my contacts sorted under different subfolders (i.e. personal, work, family, etc)
If not, does it sync with categories then? And if I have custom categories in Outlook (i.e. not default), would these categories be created in the phone during the sync process?
Thanks in advance! 😊
Thanks for the info!
I saw a workaround method in this forum applied to a SE phone, would this work for Nokias as well or is there another way?:
OK, I have managed to find a workaround - I'll post it here for the benefit of other poor souls who buy the thing and have the same problem...
Get your contacts in several different contacts folders in outlook. eg:
Contacts - Personal
Contacts - Colleagues
Contacts - Work
Contacts - Useful
Also have a separate Contacts folder just for syncing with the P900. Start with it empty, and sync with P900 (Full sync settings - merge items). This will blank the phone's contacts (doesn't really seem to be merging to me, more copying PC to phone, but we'll ignore that...)
Now, COPY (not move) the first folder (eg. Contacts - Personal) into the Contacts folder to sync with the P900. Sync.
Go to the P900, open the contacts manager. Select "Unfiled", and "Select All", then Move all the contacts to the "Personal" Category.
Back to Outlook.
Copy the second folder (eg. Contacts - Colleagues)into the Contacts folder to syncwith the P900. DO NOT ERASE THE CONTACTS THAT YOU PREVIOUSLY PUT IN HERE or else they will be erased from the phone when you sync! Sync.
As before, go to the P900, open the contacts manager. Select "Unfiled", and "Select All", then Move all the contacts to the "Colleagues" Category.
Continue doing this until you have synced all the folders.
Pros:
Saves you going through each contact separately and selecting a category
Cons:
When you synchronise, your contacts will be sync'ed to the main Contacts folder in Outlook, not your subfolders, so if you ever need to sync them from scratch you will lose the categories, unless you keep your subfolders updated separately (which would be a real hassle )
Hope that's of some help, seems to have sorted my problems to a certain extent.
i have a e61i.
think there isn't a default unfiled group/category on the phone.
in any case, if you spend all your time re-categorizing the contacts into groups.
outlook will not recognize your groups in the phone.
when you switch to a non-nokia phone, or if you need to restore from outlook,
you fall painfully back to square one.
think about it 😞
