hy! i got a huge problem wit my N80.. everytime i tried 2 reinstall my themes which i ave unistalled, it always says "unable...." how can i solve this friggin' problem?
** can't reinstall themes in N80
i faced this problem while ago the only solution that worked for me is format both the phone memory and the memroy card and it will work fine after that
If you can find a program called UnSis on the internet...then you can:
- "unsis" the theme file
check post#6 step 1 and 2 in: http://www.mobile9.com/invboard/index.php?showtopic=30787
I don't use winsis though.
- put the phone on offline mode, copy the extracted directory in the import folder on your pc to:
private -> 10207114 -> import directory on the memory card
- voila the theme is back
HTH
but i install the themes in my phone memory.. last time i've deleted all the themes in the "unistall" folder, still doesnt work.. it keeps sayin' "unable to install"..
MyN80 wrote:but i install the themes in my phone memory.. last time i've deleted all the themes in the "unistall" folder, still doesnt work.. it keeps sayin' "unable to install"..
yeah...got that problem before as well. The only way I can reinstall my theme is doing the above steps and put it in the memory card since I didn't feel like resetting my phone.
i've tried it b4, but doesn't work.. btw anybody know how i can change my N80 font?
