N95 keylock / backlight dichotomy
2 replies · 6,687 views · Started 14 May 2007
Is there an app that'll let you to adjust the N95's backlight time-out ?
Or an app that'll allow you to stop the keylock coming on when you're in standby with the slider open ?
I've tried : -
- Autolock
- Handy Keylock
- Best Keylocker
- Tetronic Keypad Locker
But none of them allows you to disable the keylock in standby with the slider open.
No problem if you have an app window open - but none of them disables keylocking by process (rather than by runnning app).
It seems that the N95 is default set to activate the keylock when the backlight goes out (max 60 sec.s) and as yet, no-one's written an app that lets you adjust backlight time-out - or better still, an app to stop the keylock kicking in when the backlight goes out.
So I have to carry on unlocking my phone after 60 secs, even though the slider's open.
I can set Best Profiles to keep the backlight permanently on, which is great (the backlight turns off when the slider's shut) - but it also stops my Clock Screensaver from running.
Have u tried going to Menu > Tools >Settings > General > Personalisation > Display ...... there's light time out at very bottom of options if u scroll down once in that "display" submenu..... and i think there's a power saver time out setting in that menu too.
Hope this is what you were looking for.
Pheonix SZ wrote:Is there an app that'll let you to adjust the N95's backlight time-out ?
I've tried : -
- Autolock
- Handy Keylock
- Best Keylocker
topned wrote:Have u tried going to Menu > Tools >Settings > General > Personalisation > Display ...... there's light time out at very bottom of options if u scroll down once in that "display" submenu..... and i think there's a power saver time out setting in that menu too.
Max powersaver time-out = 60 sec.
