Need these files ==>
1/ Map called "english male" => Contains the audio files, of the male voice navigation commands.
2/ The XML Document "config"
Anyone who still has the male voice guidance during navigation, could be a donor 😊
These files can be found on your memory card.
To locate these files, please follow these simple steps ==>
1/ Connect your Nokia N95 to your PC using the provided USB cable.
2/ Choose for connection type A/ mass storage or B/ data transfer.
3/ Locate in Windows Explorer your memory card, the memory card should be displayed as a hard drive.
4/ Then to locate the files go to the following maps *Private *20001f63 *English
5/ The map "English" contains the files I need A/ map called "english male" & B/ the XML Document "config"
Can anyone PLEASE post these files, or send them to me by E-mail ?
This way I can restore the previous audio files for English male voice navigation commands.
I want to get rid of the female voice commands witch I have now.
Any help would be highly appreciated.
Best Regards,
Marc.
