Hi,.
I have set up Fring on my new N95 and set it up to open at startup. THis was happening fine in my home WLAN but i am now at work without a Wireless connection and when the phone restarts, as soon as it loads Fring the phone crashes. This just continues in a circle so i cannot start the phone!
Help!!
Can i put it into safe mode or can i stop Fring from starting wihtout entering the application??
Thanks!
Just an idea (only had mine for three days): Try starting it without a SIM card. This will force offline mode - that might help...
-- Klaus
Ok, just disabled Fring and it is still happening. It is ok and then suddenly the opening Nokia screen appears - then after loading after 20 seconds it cuts out again and this keeps on happenning until i take out the battery!! Any ideas??
Remove Fring, then turn off phone and remove battery... then try reinstall.. if that doesn't work then wait for them to update Fring..
