Video(mp4) encoder for NSeries mobiles
0 replies · 1,903 views · Started 14 May 2007
Recently I got myself an N95, but couldn't find any video encoders that produced MP4 videos playable on it.
So I added support for it to a generic MP4 encoder frontend I wrote earlier.
If you use it please let me know if it produces videos compatible with your NSeries mobile, because I can't test it on all the models.
ht*p://bh0k441.googlepages.com/xyncoder
XYNCoder is an all audio/video formats to MP4 batch encoding frontend.
It can convert any audio or video file, that can be played back by
MPlayer, to MP4.
It supports two target profiles:
* Unrestricted: Encoded video can be played back by popular desktop video players
* Nokia NSeries: Encoded video can be played back on Nokia NSeries mobile phones(feature not tested on all models)
It uses the x264(mencoder) for video and aac(neroaacenc) for
audio encoding. It can use AviSynth(optionally) to perform any preprocessing on the source. Also it can be used as a standalone encoding frontend for NeroAacEnc.
Just add the files to be encoded, specify the encoding settings
and hit 'Encode'. XYNCoder will run the required processes in
background with low priority so you can perform other important
tasks while encoding.
Video(Mencoder) encoding settings:
XYNCoder can encode using 4 different modes:
* 1 pass crf mode
* 1 pass bitrate mode
* 2 pass bitrate mode
* 2 pass optimal quality mode (default)
The last mode is the reason why this tool was written in the first
place. This mode can be used for 2 pass encodes where the
target size is not as important as the final video quality. It
produces high quality 2 pass encodes with a single click.
This is how it achieves that:
* perform the first pass encode with a crf set to 16
* perform the second pass with the target bitrate set to half of the first pass bitrate
This method invariably produces high quality 2 pass encodes with
often surprisingly small file sizes. Most of the advanced encoding
settings are hidden from the user and have been preset to
provide high quality encodes. The only setting exposed is the
deblock filter strength, which provides pretty good results at the
default of 0,0.
The user can also specify the usage of AviSynth here and then
edit the script to suit his needs.
The 1 pass crf(constant ratefactor) mode is to x264 what other
codecs refer to as the constant quality mode. The recommended
values of crf are in the ranges of 18-28, with lower numbers
producing better quality/higher filesizes.
The remaining two modes use the bitrate as a guiding factor.
Audio(NeroAacEnc) encoding settings:
XYNCoder provides different quality settings for audio, the default
"CD Quality" should be enough for most cases. Additionaly the
audio can be set to be normalized.
