Voicemail kicks in too soon
4 replies · 4,143 views · Started 15 May 2007
Dont know if this is a service or phone issue, but how can i set my n73 to ring for longer before my voicemail kicks in??
Cheers
That is a carrier issue. I believe you can usually access it by going into your voicemail box, and changing it there
Dam, im with 02 in the UK and im sure i listened to all the voicemail menus last night which didnt help. :con?
I had the same thing with the Nokia 6630 on Orange about a year or so ago, rang orange who gave me a code number to type in, which increased the time from 20 seconds (which i think was the default) to 30 seconds
Maybe O2 customer services can help you????
Menu:Tools:Settings:Call Divert:Voice calls:If not answered
Then select Activate
select to voice mailbox
then you can set the delay time
from 5secs to 30 secs at 5 sec intervilles.
That is how i set it on a none branded N73 on O2 and T-Mobile.
any other questions then ask and I might be able to help out.
Finbar
