Nokia 6630 won't switch on or charge
1 replies · 2,186 views · Started 15 May 2007
I have not used my 6630 for a while as it is my backup phone but last time i used it was fine. I had cause to need recently BUT when i tried to switch it on nothing happened. I tried to charge it and still nothing. I have no idea if this is the display or whole machine and don't see how i can tell.
I removed the battery and refitted it, no luck.
Has anybody else encountered this kind of problem and go any bright ideas as to what is wrong?
The battery went really low. Connect the phone to the charger and try to power it on after half an hour or so.
