P990 8GB capable?
3 replies · 4,502 views · Started 15 May 2007
Does anyone know if the P990 can use a 8GB Pro Duo memory stick? I an hearing conflicting things. The Sony style store said SE phones can only take 4GB. And 8Gb is for cameras and PSPs? Called SE in the US and they said the same. Are they just playing it safe?
Has anyone bought an 8GB stick and it works well on thier P990?
Biff
Thank you for contacting Sony Ericsson Online Support.
The P990i has been tested to work with a Memory Stick Pro Duo up to 8 GB.
Wait a minute. I tried my new 8GB Mem stick duo. My P990 only recognizes under 4GB. So when I transfer over 7GB of mp3 files to the 8GB duo.... it takes ita and it is visible when it is loaded on my PC screen then when I put it into my P990 if only shows some of the songs. I can see the album folders but they are empty!
I called SE customer service and they say that Mark in CS was mistaken it only takes 4GB!
Does anyone know what is going down?
B
