Hi there,
problems with mass storage.
It states that a programm is used by the memory card.
After checking a taskman and after setting the messages on the phone memory it keeps on giving me this error...
What shall I do?
Hi there,
What shall I do?
rolan73d wrote:Hi there,problems with mass storage.
After checking a taskman and after setting the messages on the phone memory it keeps on giving me this error...What shall I do?
You'll have to give us some more info here...
- What are you doing/trying to do when the error message appears?
- What exactly is the error message displayed?
- When connected to PC?
after connecting pc suite (that works sweet), I want 2 switch 2 mass storage 2 put some tomtom maps in the E:
then it states that I use the memeory card with messages .
Changed that 2 phone memory and back again with mass storage..
Again the error that it won't work because an app still uses the memory card.
I check the task manager and nothing is opened..
I have a lot experience with the Nokia and connecting
But never B4 this....
rolan73d wrote:after connecting pc suite (that works sweet), I want 2 switch 2 mass storage 2 put some tomtom maps in the E:
Check the following:-
1. Messages - are they stored in the phone memory or the memory card?
2. Do you have any auto-start programs (e.g. eRecorder, Virus Checkers) that are installed on the card and not on the internal memory?
On my N95 I have to change the messages store to use phone memory before I can start Mass Storage mode, then after I am finished I change message store back to Memory Card.
1) On The Phone Memory
2) Like I Said... Nothing Is Running In The Background...
Strange Isn't It?
open up ur fones app manager, can u see any apps that say NOT INSTALED? if so remove/delete them
all of them R installed....
thanks 2 all of U 4 replying......
So, mayb some1 else has the solution?
You have installed something (like Shozu or whatever). Uninstall it (or other apps), until the problem disappears (try after you've uninstalled an app, and when the problem goes away, you'll know which one it was).
rolan73d wrote:all of them R installed....thanks 2 all of U 4 replying......
Have you tried turning your default setting to mass storage and then plugging the usb in? Thats what I have been doing when I use mine?
Hope it helps.
to file manage your maps across to E: ?? :con?
Did all that, nothing works....
Just posted a new topic....
Now the complete pc suite won't work anymore!!!!!!!!!!!!!!!
Everytime the error pops up.... No connection type available....
It seems like there is no com port available (I have 3 available usb).
How do i get 2 the com ports in the vista?
