Problems Removing Applications
0 replies · 1,842 views · Started 15 May 2007
I have a Nokia N95, obviously. Otherwise I wouldn't be posting something under this topic. I have several applications that I have dowloaded and installed onto said N95. Most of these applications work fine - if a little slow sometimes. However there are two applications that when accessed do not launch, due to this I have tried to uninstall them.
I have tried removing by pressing delete and it starts to remove and then fails, I have also tried to remove by using the application manager in normal mode and in safe mode.
Are ther any other ways of removing applications? They are installed onto the phone and not the SD Card.
Back2Basics
