USB drivers needed
3 replies · 2,964 views · Started 16 May 2007
I recently purchased an original nokia 6600 usb cable - it is labelled as a
kq-u8a - anyways it also came with the original software, i have searched everywhere for these drivers can anyone point me to the right direction, that would be very helpful. I have checked the nokia website and various other websites, and had no luch.
Thank you in advance.
Ok i have the drivers they were on the Nokia CD, stupid of me, anyways when i go to Nokia suite and it comes up with "is this your first time you've used this" click ok, i click ok and nothing happens, any ideas ?
Can't be an original Nokia USB cable for the 6600, because the 6600 has no actual USB cable connector. Just infrared and Bluetooth PC connectivity, using the PC Suite for Nokia 6600.
ruderussuk wrote:I recently purchased an original nokia 6600 usb cable - it is labelled as a
Install the software which was on the USB cable box.
