Updated US Nokia Store N95 to New Euro1 Firmware and Messed up Bluetooth...
2 replies · 2,725 views · Started 16 May 2007
Guys,
Just a heads up, I changed the product code on my US Nokia Store bought N95, 0548763 to the Euro1 Product code, 0536062 and then did the software update and since then it will not connect to my Kenwood bluetooth stereo after the first pairing. It worked fine before the firmware. I tried several hard resets and reflashed the firmware to no avail. Hopefully it will get fixed in the next update. If anyone has any ideas let me know. I did NOT install any backups from the old phone after the update either.
Thanks,
Y2J
This happened with me too. All I did was search for a new device on my phone till I found my notebook and pair the devices again. It works fine now.
Just a quick update. After the initial pair, the phone works with the headunit. Then when you leave the car and return to it, the head unit hooks up to the phone, but will not dial out. Once I then disconnect the headunit from the phone and then turn off the phone's bluetooth and turn it back on and then connect to the headunit from the phone, it works again.
Y2J
