hi
i recently installed a new app on my 6630
its deskoper
displays the shortcut icons on the standby mode of your 60(2nd)
just like in 60(3rd)
but the app doesnt run when i start it, the screen blinks for a sec and then nothing
i had the same prob with some other app but i thought that the app were corrupt or something
but since it runs fine on another fone(6630 aswell) then i definatly have a prob
please help
:con?
app not running
Could be anything. Could be something wrong with the install, your phone or the standby screen.
From what I've heard you can't change the standby screen anything more than either having it "active" or by not. Did you set your phone to have active standby?
i dont understand the active or the inactive option
6630 doesnt have icons displayed in the standby mode. thats why i installed the app.but the app isnt starting. it works fine on another 6630 so the fault isnt in the app.
ive found it from this link and the app works fine on his 6630
http://www.allaboutsymbian.com/forum...ad.php?t=59821
will a soft reset help?
So, I just read up on the subject. Apperently you have to install python first, if I got it right. You can get it here: http://www.forum.nokia.com/info/sw.nokia.com/id/ee447e84-2851-471a-8387-3434345f2eb0/Python_for_S60.html
okay 3 questions
what is a phyton(im guesing its a programming language)?
and which file do i downlaod?
is it a sis file that i have to download on the phone or a software on my pc?
ya i downloaded the file from the link u send me
the app still isnt starting
i dont know wheather im supposed to run it from python(and i dont know how to either)
but when i run it on its own afer i installed the python it starts but then shuts down before showing any menu
so its better then b4 but still not running
maybe im not using the right version of pyton
i have a 6630
