Please help me out with this 1
After installing the latest pc suite 4 the N95 I can't connect.
Error states: No available connectiontypes, wizard is been closed. Install pc suite again (dutch language translated)
I called Nokia care, they said uninstall the lot and all the other Nokia software.
Then clean registry (I used TuneUp) because pc suite cleaner won't work on Vista.
The reinstall but that didn't work.....
Please, some1?
Why not try using an earlier version of PC Suite?
rolan73d wrote:Please help me out with this 1After installing the latest pc suite 4 the N95 I can't connect.
Please, some1?
what does the phone say/do ?
I've had this a lot too. A reboot usually resolves it.
However the software (like much of the phone) still seems very buggy.
Please, some1?
I think Windows Vista might be your problem....trying running it on a Win XP machine and u might have better luck.
Earlier version didn't work as well.
I don't have a XP machine anymore.....
Maybe there something wrong with com ports?
No connection type available still pops up!!
I worked before on my vista, so there has 2 be a solution...
Thanx 4 replying dudes and gerls.....
It seems like there is no com port available (I have 3 available usb).
How do i get 2 the com ports in the vista?
