How can you upload pictures to the nokia photozone service?
The help file only says: "surf with your nokia to www.clubnokia.com, login and go to upload picture... " or something like that.
I tried this but login fails. Wevviewer gives an error message "no HTTPS".
I tought webviewer was able to handle HTTPS?
And do you really need to surf to there to upload pictures? What about the Image Upload server settings? Nokia services should work with that right?
Next thing I did was registering fotodock. I used the correct settings (like they say) but when I try to upload any picture it says "GPRS connection not found" and then "Failed to connect fotodock".
I use an PC Internet share connecton on an IR port. All other applications like Webviewer, sending/receiving mails and surfing work fine with this connection. Why doesn't the upload protocol work then? I mean it's like sending/receiving mails (wich works fine even with pictures included) but uploading pictures doesn't work?
Can anyone help me with this?
Thanx again.
Nobody can answer this???
[quote="Boeky"]How can you upload pictures to the nokia photozone service?[/quote]
you just have to use an unlimited internet connection (i.e. not a wap connection that lets you only connect to your provider's wapgateway, but a full internet connection) and then use the option in the photo album app.
No, webviewer does not support HTTPS. And, personally, I wouldn't trust connecting to sensible data with that "browser" that filters everything through a proxy server in Reqwireless premises.
Also, I don't know if you can upload from other apps inside the nokia (maybe wap browser?) but you can upload and edit photos connecting to www.club.nokia.com from a normal web broswer (only with a PC)
I don't use a WAP connection With the wap connection I wasn't able to mail or use WebViewer.
With the connetion I use now, I can send/receive mails and use Webviewer.
I can also use the PC Share connection, wich i also use to send/receive mail and use Webviewer. So that should be a true HTML connection
But i thing it rather should be a true GPRS connection in order to use the opload server settings.
