~~~***!!!plz Help!!!***~~~
2 replies · 1,282 views · Started 17 May 2007
When I turn on my 3650 phone it asked for the pin code
then it continues loading,it gives an error "eTelServer closed"
and then it restarts and then the same again.
Could you plz tell me what to do?
:frown:
You could try to reset it, I've hade simlair problems with my old 3660. I rested it until I got the chance to reset it. Try that.
If you mean the trick with the green ,the "3" and the * buttons pussed while powering on the phone it isnot working :frown: .
I try that too many times but nothing it always restarts. 😡
Thanks anyway.
