Hi there.
Got my new nokia n95 a week ago put 2 albums on it using the nokia pc suite with no problems. I went to put some more on yesterday and the phone and pc were not connecting? I could connect via mass storage, media player etc but the pc suite was not connecting so i cant upload anything????
Any help???????????
If you can connect via "mass storage" then you can simply drag and drop files as you would use any folder in windows.
don't use the nokia pc suite and simply connect your phone to the pc and select "open folder to view files" option on the pop up autorun window. Or open windows explorer (ie my computer) and navigate to your mass storage drive. (most cases e: f: or g😊
Incidentally, if you put a brief summary of the problem in the subject instead of just 'help me' you will probably attract more attention
Man, why can't people have that same mentality as you 3shirts, it makes life so much easier!
cotton1 wrote:Hi there.Got my new nokia n95 a week ago put 2 albums on it using the nokia pc suite with no problems. I went to put some more on yesterday and the phone and pc were not connecting? I could connect via mass storage, media player etc but the pc suite was not connecting so i cant upload anything????
Any help???????????
Uninstall and reinstall latest version of PC suite or if you have a card reader copy and paste to your mem card. The appropriate app will create the association.
