Multiple Access points possible?
1 replies · 2,323 views · Started 18 May 2007
Hi all, i am trying to have access ponts on my phone for orange and t-mobile, as i randomly swap sims.
Only prob, is, if i create the access points for one, the other vanishes???, i try renaming them, and they still go, so everytime i swap cards, i have to run the wizard to re-create them, any ideas, no option to lock them or anything.
JasonRK wrote:Hi all, i am trying to have access ponts on my phone for orange and t-mobile, as i randomly swap sims.
for the carrier you are not using ..
ie .. tools / settings / connection / access points .. pick the one you AREN'T using and change its "data bearer" from packet data to wireless lan
give it a try .. and good luck!
I have a dual sim card adapter someplace .. I just haven't tried it out yet .. thing is I have 2 numbers with the same provider .. be interesting to try it with two different providers 😊 they're cheap .. got mine on ebay from hongkong .. probably under 10 pounds. might be a longer term option.
Woot! found it .. will try it out right now and report .. meh couldn't get it to work .. back to using Sharp 903SH as my business phone ..
if anyone has found one of these dual sim things that works please let me know - PM is okay!
