HELP!!! Nokia N93i Unlock Code
1 replies · 7,892 views · Started 19 May 2007
Ive got a nokia n93i and i changed the lock code on it the other night when i was drunk haha, and its not that i forgot it, i think i pressed the wrong button twice and long story short, i got no idea what my code is..... ive been searching all day trying to find a way to unlock it but no luck.... if anyone could help it would be awsum !!! i either want to just reset the lock code bak to 12345 or something that works, or if i have to, do a hard reset...do hard resets work? and if so how do u do them?
thanks
-David W
Heh cool!!
Here is the solution for unlocking..
When i'm searching for unlocking my mobile i'm very much astonished to see the cheap unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
I made use of that site for unlocking my Nokia mobile with this unlock code it worked out great & got good result.
Try out this site for unlocking your mobile & gain solution..
This site provide unlock code & instruction at cheap cost
Cheers-)
