Software Differences Between E50 & E70?
3 replies · 2,212 views · Started 19 May 2007
About 2 months ago I brought my other half a new Nokia E50, which seemed to be loaded with different applications, QuickOffice, Teams, Search, & Msg Reader. So when I upgraded my work mobile to the Nokia E70 yesterday, I was expecting to see all the same apps. However, although it has a few others like Printers, Sheet, & Screen Export it is missing all those mentioned above!
I understand both these phones run the same version of the S60 OS, v9.1, so is it possible to add these missing applications? I�d find some of the missing apps such as Msg Reader quite useful!
Many thanks
Ben
You'll find that most of the "missing" apps can be downloaded from "one of the Nokia"'s websites. They're spread out all over the place, in the different regional websites, and in the sections for each phone model. Also some of the more "prominent" apps have their own "websites", eg the Search app. Not much point in me giving links because Nokia change their URLs as often as their underpants (I hope).
desertrat wrote:Not much point in me giving links because Nokia change their URLs as often as their underpants (I hope).
LOL 😃
I've had a google, and found the Nokia-Text-To-Speech website, and downloaded the Language package & Voice package, however, after reading further it appears that the Text-to-speech app uses the Message Reader app, which I'm still having problems finding! If you do have a link, I'd be most greatful if you could post it! The only other option I've seen is to use Nuance's Speech2Go Reader, which is similar!
Ben
I'm not sure the Message Reader app is available. The best place to check is the Catlogs or Download application - that's always a good bet for getting the extra software.
