sis problem !
1 replies · 1,276 views · Started 19 May 2007
When i try to install some program on my nokia 6630, my phone wont even start installing the application. When i try to enter message where is that program with .sis, i transfered it via bluetooth, it wont get in. Why?:con?
1) Check the Application Manager setting "Software installation". It must be set to "All"
2) Make sure you are trying to install compatible apps. No apps made for S60 3rd Edition, for example, will work on the 6630 (which is based on S60 2nd Edition Feature Pack 2).
