Guys,
I have an O2 N95. Looking at using NSS to change prod code and flash with latest firmware. Is there a way I can dump the original O2 firmware so I can flash it back to original O2 if I have to return under warranty ?
Cheers
Guys,
Cheers
If there is an official O2 update on the Nokia update service, then you can simply change the product code back to the o2 product code and run the NUS. This should reflash the original firmware.
This will ONLY work if there is a o2 specific firmware update on NUS. (Currently does not exist with vodafone)
