maps uploader wont recognise phone! loads of problems syncing via blutooth, all in all vista and nokis pc suite do not mix!!!!
bloody vista
waffabix wrote:maps uploader wont recognise phone! loads of problems syncing via blutooth, all in all vista and nokis pc suite do not mix!!!!
That may help ..
http://europe.nokia.com/A4144905
good luck!😊
no help i think its just nokia vista compatability issues at the moment
What problems do you have?
I have no problems running PC Suite/Lifeblog/Maploader/Nokia Sotware Updater under Vista.
Make sure you have downloaded the latest version of PC Suite etc, as it is the only one that is fully compatible with Vista, the one that comes on the N95 CD isn't.
Have you tried using the USB Cable, Vista handles Bluetooth differently to XP, as a result many cheap bluetooth dongle malfunction, I use a TDK dongle with no problems, but to get my other dongle working I had to use modified drivers.
