I have a problem here. I'm using v 3.16 and enabled the "auto redial" function but it doesn't seem to work. Any of you guys having the same problem? 😞
does your 7650 redial?
How long you have waited? In some NW:s it takes about 30s to hang previous call.
Yes, I use this finction and it is working fine! V3.16
BR, Miro
v3.16 I have no problem with this function...
Alway redial for my phone. Never have such a problem.
no problem here!! 😃 works fine!! 😃
Hmm, will get my SW upgraded then will check again as it happened to me all the time. Or is it because of my mobile provider (Globe Philippines)? 😊
Always have to blame someonelse but never yourself.
[quote="lazzy"]Hmm, will get my SW upgraded then will check again as it happened to me all the time. Or is it because of my mobile provider (Globe Philippines)? 😊
Always have to blame someonelse but never yourself.[/quote]
im also subscribing with globe and it works fine, and i dont think the redial function has anything to do with the service provider or the network. im sure your redial is working just fine. you just have to give ample time for the initial call to be dropped and the phone will perform an auto redial! 😃
seanmiguel, thanks.
do you use BT along with your 7650? I'm actually having a hard time trying to configure to my notebook to access GPRS through my 7650 using BT. Any idea on how to solve this?
[quote="lazzy"]seanmiguel, thanks.
do you use BT along with your 7650? I'm actually having a hard time trying to configure to my notebook to access GPRS through my 7650 using BT. Any idea on how to solve this?[/quote]
whoops sorry cant help you there. i seldom use bluetooth, im an IR guy. u can use the search function of this site, http://www.allaboutsymbian.com/phpBB2/search.php or the FAQ, http://www.allaboutsymbian.com/phpBB2/faq.php i'm pretty sure you'll find something there that'll help you. 😃
