Hi, I have a Nokia N73 with Maps and a Globalsat external Gps receiver.
Am I blind, or is there no way to pull out the current latitude & longitude from the GPS?
Thanks in advance.
Thanks in advance.
Are you using TomTom?
If so go to Change Preferences and then on the forth page there is an option called GPS status, select this and you should be able to see your lat/lon (you can short cut to this page using key press 5,6,6,6,1 )
No, I'm using Maps, the free application from Nokia.
Look at the GPS data application (its in the Tools folder). Use position to view the current lat/lon.
In the N73 tools folder it is not available the Data Application. Where can I get it from?
use a freeware gps application
"gps display"
or trial like aftrack, bluesky, gps map
