Pls help: problem during firmware upgrade
1 replies · 1,415 views · Started 21 May 2007
hi,
i just got a nokia n95 from asia, and using NSS changed the product code to euro1
i then proceeded with the firmware upgrade through the nokia software updater.
after downloading the firmware NSU began to install the new firmware, and got stuck at around 1/10th of the bar.
it was stuck at this point for about 10 minutes and then the screen changed and it says:
Phone Recovery:
1. Remove battery and charger from phone.
2. insert battery and connect charger.
3. press the phone's power button for a few seconds.
Click 'retry' to continue with phone recovery.
i followed these instructions and clicked retry, only to have the same message come up again and again. now my phone doesn't turn on or anything! =(
does anyone have any suggestions?
Its "bricked", same thing happened with mine. Going to take it into the Nokia centre tomorrow. Been told they should be able to reflash the firmware and fix it.
