I'm going to get an E60, what's the best method of transfering my data across? I've seen the post for the little prog that copies all your contact details and I suppose that's the most important one but is there a program that does the lot or am I asking too much?
6600 to E60
I don�t know well E60, but like others S60v3 devices it should have a Transfer application software inside. Just follow the instruction, and is an easy process. Another way, is by Outlook.
If you have your contacts synchronized with Outlook or Lotus Notes, then it very easy. You just make a normal synchronizing between phone and computer.
nj7 wrote:I don�t know well E60, but like others S60v3 devices it should have a Transfer application software inside. Just follow the instruction, and is an easy process.
Very. Cheers. I love Nokia's.
