N95 Vodafone branded
5 replies · 2,841 views · Started 21 May 2007
How is the Vodafone branded N95?
Can the right softkey, live! shortcut be removed?
Do the menu icons change, wen you change the theme?
What are the limitations of an branded againts an nonbranded N95?
_b4g3r_ wrote:How is the Vodafone branded N95?
Yes the right softkey (as well as the icon shortcuts on the standby screen) can be changed on any firmware.
Tools->Settings->General->Personalisation->Standby->Shortcuts
You can change the two soft keys here.
Tools->Settings->General->Personalisation->Standby->Active Standby Apps
You can change the shortcut icons here.
No, the menu icons remain the same no matter what theme you have installed.
Current limitations are :
1. Removal of integrated VoIP service (Internet telephone) - This can be circumvented by simply installing applications such as fring which works very well.
2. No always the most recent firmware version. Currently the lalest firmware update hasn't been released by Vodafone.
Thats pretty much it.
Anand
Nigma wrote:Yes the right softkey (as well as the icon shortcuts on the standby screen) can be changed on any firmware.
Anand
TNX U helped me very much :icon14:
Has any1 pictures of vodafone menus on the N95?
I want 2 se, if the menu icons are ugly like on other live! phones.
