Hello
I'm presently using Roadsync by Datawiz to keep up my N95 with my server info on mails, contacts and calendar. Syncing of task is not supported in Roadsync as far as I know (and it is to my knowledge not supported in Mail for Exchange either)
Problem is that in PC Suite you have to uncheck syncing Calendar to avoid duplicates. When doing this you also choose to not sync tasks (same checkbox in PC Suite).
Does anyone know of a way (or a workaround) to get tasks synced between my N95 and Outlook (Exchange)?
At present I have to register tasks as meetings with 0min duration :con?
