I have recently got a new Nokia N95 and I am delighted with it so far.
I wondered if it was possible to assign different ringtones to different contacts and if it is how do I do it? Thanks.
you can't (correct me if I'm wrong) assign individual ringtines to individuals .. however IF you create a group .. you CAN .. so for Individual A .. create Group A .. assign Ringtone A .. etc etc
Contacts / options / create new group .. then select Ring tone .. pick the one you want .. enjoy!
Create a group, add the contacts that you would like to have a diffrent ringtone and then assign a ringtone to that group (options > ring tone). You can make a group of many or few (just one even).
Hope that helps...
Thank you - off for a play with that now.
seki wrote:you can't (correct me if I'm wrong) assign individual ringtines to individuals ..
Erm.... yes you can. Select the contact you want from the list, click on it (taking you into it), press options, scroll down to ringing tone then pick what you want from the list it brings up.
bowman wrote:Erm.... yes you can. Select the contact you want from the list, click on it (taking you into it), press options, scroll down to ringing tone then pick what you want from the list it brings up.
Thanks for the correction 😃
