Thanks thegrey,
here is what you'll see in version 1.06 (in 28 KBytes !!!!!!!!)
Domi.
what's new in vrs 1.06 :
* find/search utility to locate files
* a screenshot tool to capture screen image in jpg format (use
the 'ABC' + 'space(0)' key); the pictures are saved
continuously (with a number, ex feecr00.jpg, feecr01.jpg ...)
until you stop the capture thru the menu 'ScreenShot Off'😉;
a beep is emitted each time a picture of the screen is taken;
the files are saved in a folder named: 'c:\nokia\images\fe_img'
* in the tools menu, added a restart function to restart the phone
* the 'C' key (backspace) on a file calls the delete function for
this file (like thru the menu) thanks to Sascha Sambale for the
idea !
* when the current selected item is a directory, the delete
function deletes it and all the files and directories under
* on a drive, in the root, when hitting the 'enter' key (middle of
the joystick), you receive the informations about the drive; an
'enter' on a directory causes THE enter in THIS directory (like
the right-key of the joystick); previously, it generated an error.
* certains menus have been disabled when not available
(ex: the 'delete' on a drive ... )
* in the properties of the drives, the total/free space is displayed
bugs fix:
* it's now possible to create a directory in an '* empty *' directory
(previously : system error message)
* the 'edit' command has been disabled in the root (for the
drives)
* the 'paste' command has been disabled when there nothing
to paste (i.e. no previous cut or copy)
* the 'send' command has been disabled in the root (for the
drives)
* an 'enter' on a directory causes THE enter in THIS directory
(like the right-key of the joystick); previously, it generated
an error.
* an 'enter' on the '* empty *' directory caused a system error
