Software to reset the N95
2 replies · 6,221 views · Started 22 May 2007
what do you mean by "reset", exactly? restart/reboot? clear to factory settings? stop all running apps? kill some running app? reformat?
N/A wrote:what do you mean by "reset", exactly? restart/reboot? clear to factory settings? stop all running apps? kill some running app? reformat?
Under my old 9300i there was an app called iDesk from Arjen Broeze.
With the app you can switch between apps, do notes, restart the phone etc.
Is there a app for the S60 rd edition?
Pit
