v6.02 seams to be out i have tested one off the net and it did not sort out the map lagging thing so gonne back to legit v6.01
any one ells tryed it?
Hi - im sure this is the one i'm using on my N73, seems to run ok to me but then, the only comparison i can make is a Windows based version of Tomtom on my SPV C500....i havent run them side by side to notice any difference....
What do you mean by Map Lagging exactly?....
Regards
Markkyboy
"You don't make an omelette without breaking eggs"
