is it good to replace my 6630 with N70?
in terms of
1.speed (response time)
2.problem (stability, freeze)
heard that Nokia 6680 is losing the battle to 6630
allaboutsymbian.com/forum//forum/thread/35802/
what about N70
in terms of
what about N70
n70 is slow but talk of features and the looks definitely better . so N70 will be a good choice talkin of performance supported by features
Wirelessly posted (Mozilla/4.08 (SmartPhone; Symbian OS-Series60/1.03) NetFront/3.2)
i owned a 6630 for several months.i'm now a happy owner of a orange branded n70.speed wise, it appears about the same.imo the n70 is much better.for a starter it's got a decent amount of ram..nokia conveniently omitted any amount of ram on the 6630 for some strange reason.ie..you can multitask many apps, games etc without regular restarts.get one, they're oldish but good.best of luck.
whiskynine wrote:is it good to replace my 6630 with N70?
in terms of
2.problem (stability, freeze)heard that Nokia 6680 is losing the battle to 6630
allaboutsymbian.com/forum//forum/thread/35802/what about N70
I made a comparison between my brother's 6630 and my N70.
1. 6630 won, is alot faster in menu and opening apps.
2. We counted how many times the phones froze last week. N70 won the stability with only one freeze vs 4 of the 6630. This refers to freeze when using apps.
I would make the change to N70 anytime, but Charlie is not a bad phone either.
ratza wrote:I made a comparison between my brother's 6630 and my N70.1. 6630 won, is alot faster in menu and opening apps.
2. We counted how many times the phones froze last week. N70 won the stability with only one freeze vs 4 of the 6630. This refers to freeze when using apps.I would make the change to N70 anytime, but Charlie is not a bad phone either.
thanks all of you guys
i think that 6630 faster too. roughly try friend's before (response when press any menu, any button, any number and letter)
although it 's nature of symbian, 6630 appreciate me much.
about stability matter (6630 appreciate me much too), i'm not sure cause there are many factors effect that (app installed,...etc.)
so i have to ask you guys who used to have both
about the feature N70 much better 100%
my 6630 was stolen last week, so i have to make a choice, stay tune with the best performance 6630 or the new N70.(budget cover only N70)
ps. 6630 better in the orgonomics also, the button much easier to press (size, hardness, the 5-way navigate button)
6630 is stable, but it has memory issues. RAM is low, that's why it sometimes restarts itself. Anyway, it's you decision and keep in mind that the 6630 is also cheaper than N70. Pictures are the same quality on both phones, even if the N70 has bigger resolution.
ok, man
Does ur budget cover N70 music edition cause its a better package gives u 2o mb internal memory, 1 gb card, music stereo headset with remote control. remember remote control is a great thing to have when u use it u will know. watch out for N72 looks good offers great package 20mb internal memory,128mb card,HS-31 great headset + audio adapter AD-15 (means u can connect it to ur PC speakers or the ear phones u want to), remote control headset also works with it, music on its loudspeaker is more louder than N70 or 6630. works pretty good with 1gb card atleast faster than N70 music
nipon wrote:Does ur budget cover N70 music edition cause its a better package gives u 2o mb internal memory, 1 gb card, music stereo headset with remote control. remember remote control is a great thing to have when u use it u will know. watch out for N72 looks good offers great package 20mb internal memory,128mb card,HS-31 great headset + audio adapter AD-15 (means u can connect it to ur PC speakers or the ear phones u want to), remote control headset also works with it, music on its loudspeaker is more louder than N70 or 6630. works pretty good with 1gb card atleast faster than N70 music
thanks
i consider N70ME also
heard that nokia original mmc is not good
symbian-freak.com/forum/viewtopic.php?t=11244
so i have to choose between N70 orginal+other mmc and N70ME with in pack mmc
and N72 cons is: it doesn't have 3G and price not so different
Go for original N70 + your MMC choice.
ratza wrote:Go for original N70 + your MMC choice.
u think that way is good?
Yup. I would do this because the multimedia key is not configurable on ME, it only starts the default music player. Remember that it's your decision, don't get influenced too much. Choose what suites you the most.
ratza wrote:Yup. I would do this because the multimedia key is not configurable on ME, it only starts the default music player. Remember that it's your decision, don't get influenced too much. Choose what suites you the most.
that's right. just check out for sure
at last, whose firmware more stable between N70 vs N70ME nowaday
whiskynine wrote:that's right. just check out for sureat last, whose firmware more stable between N70 vs N70ME nowaday
I don't know about ME but my N70 is very stable. Never had restart issues, never froze after passing to 5.638... I'm really happy with it and I think I'm gonna keep it for a long time.
ratza wrote:I don't know about ME but my N70 is very stable. Never had restart issues, never froze after passing to 5.638... I'm really happy with it and I think I'm gonna keep it for a long time.
thanks, ratza
this info. is useful for me
it is sincerely a great package it comes with the ear phones supplied with N91 which gives awesome music ouput and audio adapter AD-41 inbox which anther great accessories as it converts the pop-port to a 3.5 mm jack to which u can connect ur pc speakers or ur choice ear/head phones and remember u can control the music with buttons remotely (play/pause,stop,prev,next). About MMC u can format it and re use it. but a serious choice should be N70 music edition.
nipon wrote:it is sincerely a great package it comes with the ear phones supplied with N91 which gives awesome music ouput and audio adapter AD-41 inbox which anther great accessories as it converts the pop-port to a 3.5 mm jack to which u can connect ur pc speakers or ur choice ear/head phones and remember u can control the music with buttons remotely (play/pause,stop,prev,next). About MMC u can format it and re use it. but a serious choice should be N70 music edition.
thanks for info.
agree that earphone is great also AD-41 in pack
but i heard that Nokia MMC is not good
whiskynine, you can sell the original Nokia one, or simply make a trade with another MMC.
ratza wrote:whiskynine, you can sell the original Nokia one, or simply make a trade with another MMC.
i'm afraid that there 's no one buy or trade with me
go for it no serious problems with MMC
