Does anybody know if there exist any working blog software/solution for E70? I have search the net and tried most of them and I can't find any which works.
I want to be able to at least upload pictures.
To mention some...
- Nokia Lifeblog, doesn't work. Some error message.
- blogspot.com in Opera, doesn't work
- Kablog, not for v3
- Picoblogger, not possible to login
/Marcus
Just to bump this thread up, rather than start a new one. Is there any new blog software for s60 v3?
I've been searching for the last couple of days, and picoblogger looked as though it might be the answer, but the web site you need to connect to (www.picostation.com) seems to be completely unreachable, even though you can download the software from a number of places, and picoblogger got good reviews on this site as well as elsewhere.
The comment above is the only sign I've seen that there is a problem. Did picoblogger sink without trace?
You can email to blogger.com, including pictures, though that's a little insecure as you have to keep the mail address secret, and doesn't give you much in the way of bells and whistles for formatting, etc.
